bman1bpm
- Jul 19, 2004
- 450
My motor is a 2008 yamaha 2 stroke 90 hp.
I replaced my prop today, the new one (solas aluminum) did not come with any hardware, my question is does it need a spacer between the prop and the castle nut or no?
When I took it apart it went prop, I think a spacer, then a washer, then the castle nut and pin.
I say I think because the prop had had some water on top of the hub after I took it off, I flipped the prop over (into the river) to pour out the water, and I heard a splash, like there was more than just water on top of that hub! I assume it was a spacer. Should I have reused this with my new prop? If so where can I get one? Does anyone have a parts diagram?
