wild n crazy
- Oct 20, 2008
- 68
My dear friends, please help once again. I like to bleed down the hydraulic fluid on a 79 100 HP Johnson tilt trim, I have been reading, but still wanted to do it safe, since I have to deal with hydraulic. Please help. When I bleed down, my trim should be in the all the way down or all the way up position, do I have to undo any fluid fitting to completely drain ? I see cross slot screw like on the unit, is that my fill port? and last question, do I fill the fluid with the engine down or up, I can see it's kind of hard to fill with the engine down. Thank you all in advance.
