Valley Boater
- Oct 1, 2009
- 80
I'm stuck restoring a '58 Starcraft Speedster. Many of the originals had wooden gunnel(?) trim on the top edge of the sides of the craft. Whatever was came on my boat is long gone. My boat has nothing but the exposed sharp edge of a single sheet of aluminum. I tried to make a wooded trim but after ripping a clear piece of white ash, routing a eased edge on both top edges and making a slit in the bottow of the trim but can't bend the trim unless I steam it and don't have access to a 13' steamer. I would rather replace it with some aluminum top cap (gunnel rail?) or whatever it is called and not have to worry about it weathering like wood.
Does anyone know of a source that I can purchase this type of trim? This would be the same top-side railing that you find on any Jon boat or other small aluminum boat. I even purchased a tree damaged 12' salvaged aluminum boat hoping to salvage the railing off it but it was tack welded and wouldn't budge. My $50 salvage boat brought $33 at the scrap yard!
Any outlets you can suggest?
Thanks - Don
Thanks - Don
