I have a 1974 Merc 500, 50hp, ser#3482234. Have had a real running and stalling problem this year. Did a link & sync, helped a little. Compression 125# on all 4 cyl. Good spark. Pulled the plugs, #1-3 all showed normal wear. #4 was dry and shiny as the day installed. Could it be a reed problem? Bottom carb feeds bottom cylders, right? #3 is firing. Any ideas would be appreciated.
