philipjames5k5
- Apr 5, 2012
- 89
Just went and looked at a 1996 Suzuki that was clean as a whistle, direct injection, mostly everything checked out. My concerns are the motor took about 30 secs to start peeing and when it started peeing it still wasn't all that strong. I know its an easy fix. Also when started it didn't smoke hardly at all. My tohatsu smokes decent with 50:1 mix. So how can I tell if the direct injection is working with out gambling the motor. Also compression was between 96-108 cold. And engine has set for a couple months. Is this motor worth picking up for 5-6 hundred bucks.?How can I tell if the direct injection is working properly. And are these comp numbers decent? Comes with all controls and tilt and trim
