Ski Pylon question
64osby
I picked up a ski pylon at an auction the other day.
I am looking at mounting it on my Starcraft Mariner. I'll have some questions when mounting probably.
Right now one question is what is all this mounted to it. 2 coil springs in plastic tubes tied to a brass ring and clipped to a blue wood piece laying over the top. Anyone have any ideas?
Anyone have an idea on who might have made it? it's 48" tall
79Merc80
Re: Ski Pylon question
The bigger piece bolts to the floor and the other 2 clip over a piece (Looks like a miniature hitch ball) on either side of the outboard. I hope that explains it some. Others will be on soon with a better explanation.
Craig
64osby
Craig you must not have read what question I asked,
but thanks for reminding me how to mount it.
haulnazz15
The springs look like some sort of jury-rigged contraption for combating a slack hit. Sort of like a shock tube, I would be surprised if it were factory. Remember not to tow tubes off of that thing.
skibrain
I would remove the blue donut, 1/4" nylon rope, turn buckle, springs and vinyl tubing.
None of that is part of the original design.
Swivel-eze is a common brand for these. Over the years the actual tow point has changed from a ring to something that will rotate with a nylon bushing, but the rest has stayed pretty much the same.
On that particular design there is not much of a flange below the actual tow point. It may have been that the prev. owner had problems with the line dropping down and fouling in the side braces - the blue donut added to keep it from dropping. My best guess.
64osby
sb - Thanks, pretty much what I was thinking, but you never know.
Now it's time to see if the bottom plate will come off.
G & Me
I have a zizzer ski pylon tow for 1998 bayliner capri I need replacement pole any know where I can find one
