Hey Guys,
New to the forum and I gotta say there is a wealth of info on this board.
Well, I've searched and searched and I'm heading in the right direction and can't figure my issue out.
The boat is a 1979 Grady White with a 305 Mercrusier and omc outdrive. New batteries, batt cables are clean and newer, power to solnoids and starter, gauges work, bildge pump work, etc. When I hit the key all I get is a click from the slave solnoid. When I jump the starter solnoid the engine will crank.
Also, the power trim on the outdrive doesn't work. Then I hit the switch to lower and raise the outdrive all I get is a click from the solnoids. Related to the starting issue??
Any help or direction would be great. I'm pointing toward a new starter solnoid. Thank you!
