1988 V6 Evinrude 225
When checking the cylinder bores for roundness, should the crankcase casting be bolted to the block and torqued to spec. or doesn't it matter?
I will be taking the block to a local engine builder who has all the proper equipment to check the cylinder bores and pistons.
I just don't know if I should bring it to him with the crank casting installed and all the bolts torqued. At minimum I plan to install the crank casting loosely bolted to protect the mating surfaces.
Thanks in advance for your replies.
