Power pilot?
Wind dog
Hi All
I have a 1981 (I guess) 35hp Evenrude, The controls are Evenrude power pilot, the shift / throttle control lever acts funny, let me describe.
The lock button works fine, you shift into forward & it shifts but I don't get any throttle until the lever is all most all the way forward, coming off of full throttle it won't drop RPM until almost half way back to neutral & then it drops all of a sudden. In reverse it shifts fine but won't come off of low idle at all (I'm guessing this is correct, going fast in reverse would only swamp the boat.)
I plan on tearing into it in the next couple days, and I hope it will just be a matter of some cleaning & lube, any idea what I'll find.
Thanks!
Steve
Note: This is to replace my Johnsonrude controls thread, The tittle was terrible! BAD Winddog!
I fiddled with it a bit last night, what does the screw located on the front of the control (towards bow) in the upper left hand corner adjust?
Also can I put it in gear with only muffs?
Thanks
emoney
Re: Power pilot?
Here's a look at "what you find inside"
There's adjustments in there, but start with some WD40 to get things loosened up.
Wind dog
Re: Power pilot?
That's the one! Minus the electrical, it must have gone bad at some point, all the wireing has been cut.
Wind dog
Re: Power pilot?
So I pulled the bottom cover & disconnected the cables. While there is a small amount of slop in the mechanism it operates smoothly, the throttle cable however seems to have a sticky spot. I pulled the cables out of the sheath a little bit & WD'd both ends, then it was time for bed, uh I mean let it soak.
The screw I asked about is the warm up idle adjustment. Here's a parts pic.
