67firebird
- Sep 24, 2012
- 8
will a weak fuel pump make my 60 hp johnson hard to start after it has warmed up, then allowed to sit a while. it is a 91 j60tleib. used to be a vro but i removed all that and put on regular pulse pump. the pump was an old used1 from a 83 140. cold starts are ok but when i run down lake to fish awhile then try to restart it will only start if i do the fast idle and primer. wot is great so maybe pumps not the problem. carbs have been rebuilt, all new fuel lines and primer and fuel filters. compression 110110 108. idles a little off and wants to die at low speed
