Re: Merc 90 backfiring
I'll go for plug wiring order....wrong CDM connected to a particular plug or you got the wrong input wire to the CDM. Otherwise, you may not have your timing set correctly. The idle timing is 2 BTDC whereas the high speed, if set with the plugs out and engine spun by the starter is 22 BTDC.
CDM1 which I assume is the upper most, connects to the top plug and input wiring color codes are: Blk, blk/yel, PPL (purple), wht/grn.
CDM 2 to second plug and input: Blk, blk/yel, brn, grn/wht.
CDM3 to bottom plug and input: Blk, blk/yel, wht, grn/wht.
Right out of the manual.
Mark
