old mercruiser
tomextra
where does the wire go from an old trim indicator for a mercruiser 898 w/v8? This is on a 1970 mirro rally.
Re: old mercruiser
Ayuh,... Welcome Aboard,...
Donno which wire yer askin' 'bout, but the trim Sender is wired to the trim Gauge...
tomextra
Re: old mercruiser
The one and only wire on this sender goes to the starter button. This sender is on the back wall and has a cylinder that it screws on. Ever seen that before? Tom
Re: old mercruiser
Ayuh,.... Reverse lock maybe,..??
Up in the Adults Only section, at the top of this forum, follow the prompts to the Mercruiser manuals,...
You need #1...
