Re: Can my 72 25 hp johnson lower unit be put on my evinrude 1982 25hp modle e25rcnb
Ooooh you're right. I guess through prop exhaust didn't come till later.
Well, this is a trick I did several years ago in this same situation. I took the drive shafts from both lower units and cut exactly equal lengths from each then threaded the top piece that fits to the powerhead and the lower piece to the lower unit, you want to use. If both drive shafts are the same diameter, it will work. If their 1/2" diameter, for example, then thread them 1/2 - 13 thread and get a coupler that like 2" long. The threads have to be cut perfectly square and straight though, or your drive shaft won't spin smoothely.
Before you go through this procedure though, make sure that the lower unit will bolt up okay.
