Gentelmen, I have a Johnson 1960 33E69A that has a hole in the gear case I need some advice on. The hole opens into the exhaust cavity and I am assuming it is a drain hole that possibly hot xhaust gas has burned out into a larger hole that a previous owner tried to patch with J.B. weld. I have the lower unit apart now for a rebuild and need to know if I should weld this hole up and redrill to original size, or am I really off base about this and should just weld it up.
Thanks ... Frank
Thanks ... Frank
