Whidbey
- Jul 10, 2012
- 62
I asked about this before and Don S advised to pull it apart and check. Did that, and I think the pulley is out of whack. The damper appears to be true.
The problem is that the bolts or/and the holes on the damper are stripped (apparently the PO tried to fix this also). So I need to pull it and reinstall (can you recommend a good tool for this...lots out there on the market) also need a crank stop to torque the pulley bolt. Whats a good set up for this job regarding special tools?
Volvo Penta parts are way more money than others, can you recommend after market damper and pulley or can I get the damper drilled and tapped and the pump holes widened.
Thanks!!
Thanks!!
