I just took my boat out for the second time in two weeks. The first time I had no issues, but the last time was different.
Both times I had to pour some gas in the carb, but it started fine after that.
However this last time it would die as soon as I gave it any gas, but it would kind of run when just put in gear. I looked in the carb and i could seen a little gas and vapor when the throttle was pumped. I later figured out that if while at idle, if I pumped the throttle a few times real fast it would work. While at full open it seemed to run fine.
Could this be a fuel pump??
Thanks,
Dylan
Thanks,
Dylan
