what is this part??
ls1adam
ok wondering what this parts purpose is and is it important?
Lyle29464
Re: what is this part??
It keeps the boat from moving forward if you stop fast.
mohead1
strange trailer set up.....should have a solid bow stop, with a cushion (rubber or polyurethane)......move the spare and remove that thing, fabricate up a nice support stop and youre in......
its a combination bow stop and safety link.
Silvertip
It prevents this from happening - especially if stern tie downs are not used.
ls1adam
oh man that would SUCK.
the bar is just a PITA.
the guy i got the boat from said he never used stern tie downs. it seems more safe to use them though
your supposed both the bow safety and the stern tie downs.
JimS123
Stern tie downs are required by law in most every state. Better check your regs to see if you're legal or not.
ls1adam
oh im using them, im saying the previous owner said he never did.
oldjeep
Not too uncommon with an inboard. I rarely ever see transom straps on comp ski boats. That trailer looks like one we had an old jetboat on.
Silvertip
What's special about an inboard? Physics is not partial to what a blob of material looks like. It is a weight that is in motion. An object in motion tends to stay in motion and that applies to any axis - not just fore/aft. Lots of folks overload their trailers, they use a clothesline rope on their winch, no safety chain and no stern tie downs and get away with it. That doesn't make it safe. It makes them "lucky"
MH Hawker
I have use them on ever boat I have owned even the pontoon boat I now own. Its just plain safer.
catfishcarl99
ya i dont ALWAYS use stern straps but i have a good winch strap, and a safety chain the hooks on my bow hook. i never un hook it till im backed in and ready to uncrank the winch to un hook strap hook.
oldjeep
Not saying it is right, just that it is pretty normal to see no straps on an inboard. My father inlaw has never used them on his Malibu, not even sure that there is a place on the trailer to hook them up.
ls1adam
ok i took the boat out last weekend, and that damn bar was a pain.
can i elongate the the cut out about a half an inch to an inch or will this do something negative?
UncleWillie
It is time for some close up pictures so we can see some details. Top and Bottom! :D
What is the real issue that is giving all the problems?
ls1adam
when loading the boat off the lake i can get it on the trailer but not far enough up to get the bar set on the bow mount.
i basically have the whole dang trailer under water. i use the winch to pull it up as far as i can but as soon as i release the winch to put the bar on the boat slides back.
oldjeep
You're trying to detach the winch cable and put the bar on with the boat still in the water?
UncleWillie
While I have never seen this arraingement... Is there any reason you could not put the bar on after you pull the boat and trailer out of the water?
Could this be done in the parking lot?
