MtnExplorer
- Sep 22, 2012
- 7
I have a new to me Duckworth aluminum welded Navigator 172 (17.5 feet in length, 7'9 1/2" width) with a F90 Yamaha motor with a 13 x 19 SS prop. The tested weight is 2,400 lbs. Using a GPS going out and back I recorded a top speed of 32.6 mph at 6,200 RPM. A Yamaha test bulletin (PB_DCK_175NavigatorSport_F90TLR_9-20-06_ALM) with almost the exact setup shows a speed of 38.2 mph at 5,800 rpm. This seems like a significant difference. The only difference in conditions which might affect the speed is that I was at 1,600 above sea level versus 770 in the Yamaha test.
I would like to know if this is an insignificant difference from a careful test with different measuring equipment.
I am not interested in top speed as much as mileage as I travel distances in this boat. Would a higher pitch (say 21) provide better mileage at 25 mph?
I am NOT interested in any hole shot times.
