The easiest would be to locate a prefab console. You can go to Ebay and they have consoles for smaller boats. You can also check on this site as well as other sites. Also, you could whip up a small console out of wood, the older 13 footers had wood consoles as options, so you would be staying within Whaler tradition. Good luck...
I'm making one right now out of teak....I drew my own plans up.....roughly 28" wide, 14-18" deep and 36" tall.go to http://www.continuouswave.com/whaler...ceaPage50.html and scroll down....this is a console on a 15' so I made adjustments (mine will look different but I got the idea from here).I looked all over for a console that I liked and since I'm also a woodworker, just decided to make my own...It will be unique,,,,not another one like it.Good luck
__________________
1996 18' Premier Odeski Tri-Toon w/ 120hp Force
1964 13' Boston Whaler Custom Center Console with 1986 Merc 35
2004 Honda Aquatrax F-12x
talk to folks in your area that build trailersor repair big trailers. the materials they usewould be perfect for this IMO. lightweight andwaterproof and they may have some scraps cheap.good luck,M.Y.
That 90 sure made it look a little stern heavy didn't it?I hope my console turns out that good! I'll have to post some pics along the way....Right now just have the plans drawn up....will get the wood next week and see what happens!
__________________
I built a stand up center for my 15 that looked a lot like that nice teak one. It had room underneath for 2 6-gal metal tanks, and above that it had a seat in the front, and room for the battery inside under the wheel. Having the battery up there was good in that it kept it dry when the boat got swamped. It was made from 3/4 luan plywood, varnished, and it looked beautiful. The problem was when water got under the varnish the outer ply was too thin to allow for much sanding. Standing in the 15 could be tricky under certain conditions because it tended to rock a lot. It might actually be better on the 13 since it has a flatter bottom.I will try to get some pictures of it scanned and post them.
