Ok, I'm getting close to having everything hooked up on my motor. I have a 1979 mercruiser 260 with a quadrajet carb and a what looks close to the airtex fuel pump. Keep in mind whenni gotnthe boat there was no motor just the external parts. On the fuel pump there is the sight tube fitting, one connection that goes about 45 degrees toward the aft starboard side, and one connection that goes close to strait aft. What I need to know is where the sight tube hooks to and which connection is inlet and which is outlet. Thanks for the help.
