tailwind 67
- Jun 24, 2005
- 34
I have finally got to installing my engine after two years with it out of the boat. I got it in position, with the rear mount bolts through and just snugged in the nuts but not torqued yet. I checked and played with the alignment and once I had that I commenced to torque the rear mount bolts. The one on the right started to tighten and then immediatly loosened. I could tell it was stripped so I hauled out the bolt, lifted the motor a bit and reached in and grabbed the nut. I was surprised to see that it is aluminum. Why is an aluminum nut used here with a steel bolt instead of a stainless steel nut? Can I use a stainless steel nut? I am thinking that there must be a reason mercruiser went with aluminum but haven't any idea why.
