I have a small lake boat that I recently put a newly rebuilt 1960 Fastwin 18hp (15032-03650) motor on. Unfortunately my nephew grabbed the wrong can of gas and damaged the engine.
I removed the cylinder head and found the top piston shattered and cylinder wall gouged. The lower piston did not appear damaged and moved when starter rope pulled.
Having several options, I decided to purchase another Fastwin 18hp...1968 (18803M-E03013) which appears to be in great condition. It has an electric starter with what appears to be a factory installed silonoid mounted inside cowling. However I can not seem to get the motor started. I changed out the fuel lines/filter/plugs... It has good compression at 125lbs both cylinders and spark.
I am thinking of taking the head and block off this engine and putting it on the other one but don't know what I'll be getting myself into.
I guess my question is should I sell both motors and save up and get a new one or attempt to convert the 1st one with parts from the 2nd.
