How much difference is there between a 15hp fastwin and the 18hp?
Kelpy
and please don't say 3hp! ;)
I'm just wondering if it would be worth my time to pick up a project 18hp when I already have a running 15hp? After my 15 rebuild and now that its working I feel a lot better about these motors. Funny how that works. It has been reliable for the last 4 trips out and now I think that maybe the 15hp might be a touch to small for my needs and 3 more hp might just be the perfect fit.
On a side note, what is a middle 50's 18 electric start worth? It will most likely need a carb kit, ignition system replacement, and a new impeller. The guy has it listed for 400 but said he would take 250. . . Fair price? or haggle some more?
Thanks, Kelpy
HighTrim
Re: How much difference is there between a 15hp fastwin and the 18hp?
The 18s in my opinion are the best pound for pound motors. I started collecting the Big Twins, but have quite a stable of 18s now too.
Do you get the harness, solenoid box, key/choke plate, etc... with the deal?
Condition is everything here. Have a pic?
Kelpy
This is all i have to go on. It says that it hasn't been run in 2 years but it ran good then. He also says it has good compression (but who doesn't say that). I will test that stuff when I get there. . .
I'm just assuming that it needs a whole new ignition system, a carb rebuild and a new impeller. . .
I don't know anything about these electric start motors. What is the solenoid box, etc? I was just planning on using the pull cord. . .
Thanks for the reply!
kbait
If it has the plug-in wiring harness, solenoid box that mounts to the transom of boat, and key plate/choke button and is all in good condition, you may have a find. Those items are rather hard to come by.. especially the plug-in harness.
I'd consider it a parts motor if he can't/won't run it for you. Spend accordingly..
Those 15's were pretty strong.. probably not much of a jump to an 18. If you can get it for a good price and make it a runner w/working electric start, it'll likely sell well if you decide to go that route. Good luck!
Chinewalker
The primary difference between a '56 15 and a '57 18 are the extra cubes. The 18 has a larger diameter cylinder bore, making it approximately 22 cubic inches, vs. the approx. 20 cubes of the 15... All of the Fastwin series are worthy candidates for revitalization...
HighTrim
Looks nice, I just restored the same motor. Ill post some pics of the harness and all.
kfa4303
Banned
I agree. I love the FD/E models. I have a '66 20 hp, which is essentially just the much loved 18 hp. Probably one of, if not the best pound-for-pound motors ever made. Mine will push me along at +/- 20 mph in my 14' semi-V hull tinny. Here's a great link that may help you decide. If it has good compression, you can fix all the rest pretty cheap and easy (<$100).
http://www.leeroysramblings.com/johnson_E-FD_15_18hp.html
