Im trying to understand the water system in mercruiser outdrives and inboard engines. Mainly a 1981 mercruiser 165 hp. Is it a closed cooling system with antifreeze and then a seperate water system through the outdrive? If so and the impeller was bad in the outdrive and it wasnt getting water sucked up what parts of the entire system would be damaged? What does the closed system cool and what does the water from the outdrive cool? How can I check this boat to see what has been effected and if that is really the problem?
