1976 55hp voltage regulator
redo
Has anyone actually put a voltage regulator on an older, unregulated Johnson outboard to stop overcharging? I'm aware of the maintenence free battery issues, turning on pumps or lights to lower voltage but I would like to do it with a regulator if possible. Must be air cooled, I'm looking for someone who has done it sucessfully, part numbers and wiring diagram if possible. This is a 6 amp stator so I'm thinking a 10 amp regulator such as CDI part # 193-4476. Any help would be appreciated. THANKS Jeff
redo
Re: 1976 55hp voltage regulator
Yes I have a rectifier, looking to add a voltage regulator as the rectifier does not regulate the voltage only converts it from AC to DC. Jeff
boobie
OMC used to have one, Part 173640 but don't know if it's still available or not.
tx1961whaler
They still have it, but it's $188 for about a 50 buck part....
boobie
Good old BRP strikes again.
redo
thanks for the help,not sure if I want to spend that much on this motor, might just have to leave the lights on, Jeff
redo
thanks tx1961whaler, i'll look into that, at least a decent option price wise.
