Evinrude Johnson electric start early sixties ignition help..
26bucker
Hello everyone..
was wondering if anyone has an "ignition wire diagram" for an early sixties model. the silver box mounted to the rear?stern area type. Its hooked up to a 63 Johnson Super Seahorse 75. the old ignition has the key broke off in it and Im replacing it with a newer 4 post model compared to the old 6 terminal...I've seen a few online but they are either too small and unreadable or there are just way too many to identify. any help before i just go wire to wire with a volt meter would be great.....
thanks
Steve
boobie
Re: Evinrude Johnson electric start early sixties ignition help..
Could you post a pic of what you have ??
Willyclay
Deleted link due to possible errors in publication. Sorry!
F_R
Yes, you need to determine whether you have a manual shift motor, or Electramatic shift. They are totally different. You may have the wrong switch. Here is the manual shift model
Chris1956
Willy, That is a very interesting service manual. I had one similar to it for my Fat-Fifties, however, the manual you provided calls for a 16::1 fuel mix for the 1959 motors and a 24::1 mix for the 1960 motors. My service manual called for and I used 24::1 mix for my my '58 and '59 Fat-Fiftys. In additon, my '58 appeared to have features of the intake manifold from the 1960+ motors, rather that what is called out for the '59. Were their serial group differences on motors of that vintage? Maybe that was an early version of a Seloc, with it's errors and inaccuracies?
