brovo trans removal
becca911
brovo trans removal
I have a 454 cuin engine with a brovo trans, are there any tricks to remove the engine from the trans? does it seperate at the flywheel/flex plate like an automatic trans or come apart like a manual trans? i've got to rebuild the 454...
JB
Re: brovo trans removal
Hi, Becca.<br /><br />Welcome to iboats. :) <br /><br />Your engine is not an outboard and you are asking about repair.<br /><br />Moving to I/O.
1st you Remove the Outdrive,......<br /><br />Then the Engine seperates from the Inner Transom Plate at the 2 BIG Bolts just forward of the Transom.....<br />The Flywheel Cover Plate Stays with the Engine......(looks like a Bellhousing on a Car)
mercrewser
Or, he may have a TRS, with a tranny. Bravos don't have transmissions. They are a shifting outdrive.
