Over the last month or so I rebuilt the powerhead on an Evinrude E60TLCEA. Bored .030 with new pistons. Everything else was in spec.
After reinstalling the engine on the boat and firing up for a test the tell tale did not produce a stream. Took off the lower unit this morning and it looks as if the water tube - connecting to the water pump outlet and up through the midsection - may not have been connected. Would this cause the problem or should it still pump enough for the tell tale to work?
