1973 Formula 180 thunderbird
Evinrude 115hp outboard
At max throttle the engine does not go past 3,000 rpms.
We just rebuilt the motor and everything is to spec. Except the pistons are 1/5 of an inch shorter. All new seals and bearings. New pistons and wrist pins. Rebuilt carbs, fuel pump, filter, primer bulb, engine starter. All new gas lines, new batteries. It throws a mean spark and the power pack checks out too. Idles like a champ goes reverse and forwards, the damn thing just wont spin above 3,000 rpms at WOT. Also we are running the recommended per the repair manual oil/fuel mix, which off the top of my head is 2x the amount of oil as normal. We have put about 3 hours of the first 10 hours of recommended 1 part of breaking her in. However not being able to get her past 3k is keeping us out of the power band and never really breaking 9mph on flat water. Before the rebuild we could hit 30+ on flat days. Why the rebuild you ask? She ate a piston ring while warming up at the dock right before we were heading out.
Any advice would be welcomed. Hopefully i have given a large enough scope of what has been done. Basically a complete overhaul of the top end. Last year we did the bottom end. Now we are just pulling our hair out in frustration as the fishing season drifts on past us.
