Re: electronic ignitions for 170 hp?
Stace:<br /><br />The 3.7L has always been a tough start...lots of cubes for a 4cyl. Check all the battery connections, cables, etc. that the others have suggested. You don't have non-marine cables do you? If so get rid of them and make sure they're the shortest distance poossible, 2 or at most 4 gauge. Sounds like some carburater adjustments might help too. Mine floods and is hard starting when hot due to some float and valve wear, and choke related issues.<br /><br />The Pertronix electronic ignition that I installed (your engine would take the same one) helps starting somewhat and makes a lot of difference in over-all performance, but won't solve your hard start issue. Part of that is inherent in the engine, may be wear related (check compression), caused by carb, or electrical related. Start with the easy cheap stuff...clean connections and cables, then progress as indicated, including starter brushes.
