hudson20227
- Jan 31, 2012
- 52
I have a 1986 Proline 23 with an aluminum jack plate/motor mount. Two issues. #1 is the tech at my marina said the motor needs to be lifted an inch or so... he said not only would it perform better I would save a ton on gas... Problem for number one... this jack plate is bolted to the transom with 6 bolts on each side. If I raise the plate I will have to fill the old holes and drill 12 more holes in my transom.... that I am not comfortable with. seems like it would weaken the transom. also the motor itself can not be lifted its mounted as high as it will go so i would have to lift the jack plate. THOUGHTS? #2 Issue which I will post photos of. The botom of my jack plate has about an 1 1/2" gap between the back of the transom and the bottom of the jack plate. This to me seems like a problem. I understand the gap is there to allow the water to flow out of the jack plate but to me with it being that large of a gap it seems like it would create a ton of drag. also the ding bats that mounted the jack plate did in fact mount it too low on the transom because on both ends there is about a inch that hangs below the botom of the boat... What do I do? would it be safe to say I could just grind the low hanging ends off making it flush with the bottom? Do I raise the jackplate? Please Help...
http://i1061.photobucket.com/albums/t480/ChumSlick/2012-09-18095325.png
http://i1061.photobucket.com/albums/t480/ChumSlick/2012-09-18095401.png
