Re: Volvo 3.0 what kind of winter antifreeze?
Ok folks, a few further points to clarify:
1) I started the motor on muffs and when the water came out of the exhaust (hub) it was slightly rust coloured for the first 30 seconds - can someone please confirm that this is normal? The boat had been sitting a week since last use.
2) I drained the water from the two petcocks (one for the block, one for the exhaust riser). Barely any water came out of the block (just a trickle - there is no way I had warmed up the motor long enough to open the thermostat). About 2 or 3 quarts of (very warm) water came out of the exhaust drain. Is this normal?
3) I loosened the clamp and pulled the large hose off of the motor (near the thermostat, I believe). I filled that hose with RV antifreeze (with corrosion inhibitor) and turned the motor over with the key (i.e. with kill switch removed so the motor would not start). I then opened the two drains again. Nothing came out of the engine, and lots of antifreeze came out of the drain for the manifold. Assume this is normal.
IMPORTANT! Do I need to do anything else with the water for winterizing? I'm going to have my engine oil and outdrive oil changed by a mechanic.
THANK YOU!!!
