1967 evinrune v foursport 60, no spark
mcnallyny
I think it is a magneto, but I,m not sure? it has a dist. cap with condenser and two sets of points. their is no spark. the wiring harness is disconnected but if i am correct it should still have spark?
the engine #60573A
peace mike
Daviet
Re: 1967 evinrune v foursport 60, no spark
You might start with a simple check first, clean and set the points to the proper spec.
F_R
Your motor 60573 is a 1965, not a '67. Makes a big difference. 1965 has a magneto, 1967 is battery ignition. Yes, a magneto shouold have spark with the harness disconnected, battery ignition will not.
I can't read most of your question because of the big ad covering it. Moderators????
mcnallyny
kool i will check points and i think thy should be. .020
mcnallyny
points that are under dist. cap are dirty. they have white crap on them, what is the best way to clean them to see if this is the problem. i read on forum to use a match book is this right?
thanxs mike
mcnallyny
cleaned and check points and still no spark?
part # for new points 580260 ? and if so can I get them at napa
boobie
You may want to stick to one post as it's less confusing.
mcnallyny
Im sorry Im trying to remove this one
thanxs for responding
