81_chapparel194
- Aug 7, 2012
- 341
1981 evinrude. 90 hp. Start off by saying. It runs flawless on the hose all day everyday. But I can drop it in the lake and it starts fine and takes off. I can dock it for a few min. And fire it up and it idles fine but drop it in gear and it stalls. I can bump the key in for the primer and it will then ease off if I feather the throttle. Or I can run the fast idle for a few minutes then take off. I just rebuilt the carbs thinking that was the problem but no such luck. Compression test was perfect. 105 -110 on all 4 cylinders. I'm thinking it may be a fuel pump problem. But tired of throwing money at this problem by guessing. But again runs fine on the hose. And it runs fine at the lake after I finally get it to take the gas. WOT or anything in between. But dock it again and it's a chore to get going again.
