hi guys
I am back again seeking some possibles answers to another problem. the other week I had a headgasket blow on me so i replaced it with no issues and it fixed the problem with water in the cylinders. that being said i thought while i had things apart i would give it a tune up, i replaced the plugs wires cap and points. since i did all of this the motor is very hard to start cold and even harder to start after it is hot and sits for a little while, to the point of killing the battery and when it does start itsputters for a few seconds then runs and idles fine. this is what i did, valves where set with the running method by loosing the adjustment until tapping was heard then tight until itstops taping then 1/4 turn more. tune up was set with duell at 32 and timing at 4 deg advance, both should be corect right? I sould also ad the motor has always been a good starting motor with just a tap of the key. does any one have any ideas where to start , at this point i do not know if it is a valve , point or carb problem . the motor is a OMC 3.0 and is a 1985. sorry for the long story just wanted to give a back round.
