hempfarmer
- Oct 13, 2009
- 80
Hi everyone,
This thing has been sitting unused for 15-20 years. Compression is 81 and 79. I am hoping to wake this thing up and make it a reliable back country fishing boat engine.
I will be performing the following service:
- Replacing entire ignition system
- Rebuidling the carb
- Replace the impeller
- Replacing the gear lube screws and gaskets
- Replaceing the gask tank and external line
- Replace gasket between powerhead and exhaust shaft
Would you also?
- Replace the head gasket? (plus get a chance to look in the cylinders)
- Replace the fuel hoses on the engine (they are original, really stiff and seem strong)
- Recommend anything else?
I am willing to spend the money for additional work as this engine needs to be reliable and I plan to use it for a lifetime.
Thanks!
Russ
Would you also?
Thanks!
Russ
