Re: "New" boat, couple of questions
I know this is an old thread, but I wanted to update.
Took a little time a couple of weeks ago to check out the motor: had to clean out the tanks (obviously), change the fuel line, and change the sight bowl gasket (the local Tractor Supply Co. had the exact gasket on a Sunday!!!). It fired up right away and just PURRS! Changed the lower unit oil and added a telltale at that point.
So, last night, the lake was like glass, and I put it in. It floats without sinking! WOOHOO! Fired up the Chrysler, and the telltale showed that the pump was working, so after checking that both forward and reverse gear worked, took it out for a VERY short test run, then returned back to the dock and loaded up the family for a 45 minute maiden voyage.
Needless to say, it's time to start cleaning and restoring.
There's one thing that concerns (or at least, bugs) me. The toons stick out behind the decking 18" - 20" or so. There's a fuel tank on each toon. When we reach a little speed, the water from the transom starts flowing up and over the rear of the toons, and begins to flow past the fuel tanks. I am considering installing an aluminum "shield" on each side, between the top of the transom and the top of each toon, to provide a path for this water to flow *behind* the toon rather than *over* it, also adding a standing platform and preventing the water from flooding the tanks. Does that sound like a workable idea? I'll try to get a pic of the area before and during a run.
Thanks for all the help and advice everyone! It is very appreciated!
