Hi, we have a one mercruiser marine engine with the id number, but I can not find, the specifications of this engine V8- 4 barrel, I take a pictures with all numbers in the engine block, and the manifold carburetor... ....Thanks in advance...Erick
Does it have a drive or is this just an engine. Those where mated with TRS drives I believe.
This is a Mark 4 454 Chevy engine. You can get any parts you need for it from other than Mercury. Yes you can put it in a boat which has a Bravo 3. You will need the flywheel housing and coupler that is used with the Bravo. Also you can use the exhaust manifolds from a Bravo. Probably came with a Holley 750cfm carb like this.
http://www.jegs.com/i/Holley/510/0-9015-1/10002/-1?parentProductId=743728
