BASSBOAT21
Banned
- Sep 15, 2012
- 35
Factory setup 2000 model triton tr21---with johnson225 ho-----evrythings been fine---changed the fuel filter to a sea sense-unverial metal one see through with interchangable filters---went to river boat started off fdine then as rpms got to 3000-3300 the light came on and buzzer sounded---check all gauages water presuure was around 15 psi or better--- battery voltage fine--- at 13.5--14---all other lights or buzzers off----i stopped eased to location cut it off checked fuel connnections near fuel filter no leaks or off hoses or vaccums--filter full off fuel ---also only run non e10 gas----cranked back up later on headed to another location--running 3000-3500 rpm no lights or buzzers---get to locaton--fished then later evening leave to go to landing--hit the hot foot to get going goes to 2000 rpm ck engine light and buzzer again stay on it levels off into plane rpms increase to around 3000 everything goes off --i get to landing load up head home----nothing evr was wrong with it until i changed filter --checked to make sure i didnt put on backwards its on right----dont know if this had something to do with it or not--fuel restriction?---filter too small?---it has 3/8 end barbs---it has thge factoryplastic one on it---its located right next to the vro pump on engine---no restrictions in line and all line were rehooked up checked more then once---all wires are connected good---any help--
