Penetrol? Any one use it?
bigheaded5
F Hull.jpgDoes any one have experience using PENETROL to remove oxidation and restore the finish to Gel coat? After the advice i got here, I was planning on compounding the boat...a good friend recommended PENETROL, so before I dive in I want to know
Is penetrol a FIX or a band aid
does it last or needs to be repeated and if so, how often?
I want to FIX the situation.... as of right now, Im going to compound then wax with a paste wax
The finish is an original mustard color gel Coat, 1972 Sportcraft.
Woodonglass
Re: Penetrol? Any one use it?
Penetrol at best is a Band Aid The compound will be your best long term remedy. I'd use a Marie Polish and not wax. Check 3M products.
Yacht Dr.
Nothing removes oxidation aside from buffing ( worst case is sanding and buffing ).
Dont use this penetrol.
Its the same debate over again .. use Vaseline or Transmission fluid in your polish mix. Why not just spray down the whole boat with silicone spray..same results.
Petrol based fixes are just a temp thing. Probably hurt you more then help you in the long run.
YD.
bigheaded5
Thank you..... Thats what I suspected. In life we all want FAST, GOOD and CHEAP. You can only get two and maintain quality. Penotrol is all 3 lol
Yacht Dr.
No.. not its not all 3 mate ..
Its fast and cheap .. not good ..
I know the triangle that your speaking of .. it not in that formula.
YD.
bigheaded5
...Ooops, I know it CANT be all 3...i meant to type..."and penetrol is all 3? LAUGH LAUGH LAUGH
In all my 47 years, i have NEVER had something that was fast, easy and cheap.....EVER! it simply can not be. Same applies to a woman :)
Bob_VT
Trust me you will NOT be happy with the results at all. I have seen it used and the results are horrible.
Yacht Dr.
In life we all want FAST, Quality and Cost.
Fixed it for ya ;)
i meant to type... i have NEVER had something that was fast, easy and cheap.....EVER! it simply can not be. Same applies to a woman :)
I disagree with ya .. Packed lunches are just that lol ;) .. I see these other guys going out for a few quick burgers or a finger pizza for 5 bucks/day while I snack on some left over yum yum dinner steak and potatoes :D .
On the woman thing .. That triangle slightly changes to "pick only one of the three " .. hope you get the Quality the first time.
That might not be true in all cases .. he might be happy with the results. Looks good .. was cost effective .. cheap.. But how long will it last ? .. not very long. Quality counts.
Peace.
YD.
bigheaded5
Thanks lol
I went OLD SCHOOL and compounded then waxed.... starting to look great...
