Fish_Molester
- Aug 27, 2012
- 6
Greetings,
I just joined this forum and I also just purchased a boat. It's a 1990 Carver 2767 Santego. We like the boat but when we took at out a few days ago the starboard engine overheated. The engines are Volvo 4.3 model 431A. They have the closed freshwater system installed.
I tried a new thermostat, but it still got hot so I swapped the thermostat from the port engine to the starboard engine. Still getting hot, and port motor works fine.
I pulled the impeller and it looked fine.
I pulled off and inspected the circulation pump. It looked fine and spun normally. I put it back on the motor.
So I've ruled out the impeller, the circulation pump and the thermostat.
At this point I'm suspecting the sea water pump. How can I test this? My first thought was to mark an impeller blade and run the motor to make sure it's spinning. Is there anything else I can do to test?
Is there anything I should be looking at?
Dean
Dean
