cdcoates43
- Sep 12, 2008
- 8
I bought a very old hull for the 1996 88 spl that came on it. I have put the motor on a newer hull I have and swapped most of the controls or bought new ones. My problem is the tach. The old one was shot so I bought a Teleflex that I was told would work with my motor but when it came in the connections look nothing like what was on the old one. The original tach had an 8 pin connector that plugged into as well as three other wires attached to the studs (I assume for power and ground). The new tach has a much more universal rear with studs for Sig, Lt, Grd and one other (I can't what).
Can anyone tell me if this tach will work for my motor and if so which wires to steal out of the harness to use it?
My concern is that maybe the 8 pin plug in the wiring harness connected the old tach to a rev limiter or something else that is vital to the health of the engine.
Any help would be great ... I'm completely out of my element when it comes to wiring and outboards and tachometers!
