So I took my boat into the shop because I could here a rattling/banging type noise coming from what I thought was the outdrive. I could rev the enging in neutral and there was no problem, but when I engaged the drive anything about 2400 rpms and this noise would start (Sounds like a heat shield on a car rattling) it got louder as I gave it more power, under 2400 rpms, I couldn't hear any noise. The place where I took it, took it out for a water test, came back and said the connector rod is gone, and would have to be replaced. They are saying that because of the age of the motor, and that is a salt water boat, and the labour that would be involved in fixing it, that I would be better off in the long run to buy a remanufactured engine and have that put in instead of rebuilding it. As you can tell I do not have a lot of experience with boat motors, I have only had this boat for less then a year, and I don't even know if it is worth fixing. I paid $6000.00 and have put about $5500.00 into since I have had it, fixing the trailer, the upholstery, trim motor, alternator, gimbal bearing, water pump, new batteries etc.....
The boat is a 1991 Thomposon 195 Carrara (20 ft Cuddy), with a 4.3L 2BBL mercruiser. I did have an issue about a month ago where the temperature guage climbed from 150'F to about 220'F. I stopped the boat, and could see some white smoke coming out of the engine bay. There was a little bit of growth on the intake so I cleared it off, started it up and there was no other issues, and I have had it out a good 6 hours after that with no problem. They are saying that would have been the start of the problem, that when the engine temperature had climbed, it would have damaged a seal around the rod, and that if finally just let go...
So is what they are telling me correct?
