flogorfish
- Sep 12, 2012
- 9
Okay, I've been searching forums and the web for a few days now trying to find help for my Mercruiser. It was running fine, hard to start sometimes, but ran good after. I was cleaning it up, getting ready to sell it (but the wife don't want me too), and started it up. It started quickly and ran up close to 3000 RPM. At this point, I had done two things, replaced the exhaust hose to the y-pipe. Earlier I'd had an impeller blow up and they got hot. I also remove the fuel/water separator (just dumped it, didn't look for water) and it looked clean. I did not fill it with fuel before re-installating it. After doing some research and thinking that there might be some object in the carb so I did a basic rebuild on it. It is a Rochester Qject. It wasn't very dirty. After installing it, I had the same exact problem. Starts quick and starts to race. I have it on the trailer and can't leave it running very long as its starting to heat up. I've disconnected the throttle cable, backed the idle screw all the way out (well - not touching the throttle stop). Adjusting the fuel mix screws doesn't seem to do anything either, but I haven't backed them out very far. I started at about 3 turns, ran them almost all the way in without much affect. I'm at a loss. The behavior is the same before after the rebuild, so I'm thinking that it is not the carb. What's puzzling is the sudden change and the only thing I touched in the fuel system before the issue was remove, dump, re-install the fuel/water sep/filter. Help!
