millieboat
- May 27, 2012
- 5
I had a bad case of hydrolock. Mechanic replaced risers, head gasket and starter. The engine of course, locked up before and the starter clunked and ground and ate teeth.
Replaced ring, starter, hydro'd again at idle and it dieseled. Drained water, clunks and grinds then just spins.
New starter again, old one looks ok, noted bolt was bent. Checked block where bolts went in and was welded but is square on the block.
New starter won't engage just spins, 3rd ring on flywheel the mechanic and I are at a loss. Can it be a relay, the boat is a 1997 Chaparrel with 5.7 holly carb engine. help this is the 2nd time in 5 years this has happened and it ain't cheap.
Thanks in advance. jj
