Hello Ya'll
New to the forum but not new to owning boats ,
I Recently purchased a 16 ft SeaArc with a 50 hp Mercury 2 stroke .
I had the mechanic power tune ,replace water pump ,thermostat ,change fluids & clean carburrators.
Checked compression in cylinders 125 psi all three
Anyway after a day of fishing in saltwater i got it home and used the earmuffs to freshwater flush the engine .
After a few miniutes of idling in driveway i noticed nothing coming from pee hole & alarm started buzzing?
Shut motor down & removed cowling .It was warm but not hot touching side of block .
Took it back to mechanic & he said he would have to replace the water pump again .
He also told me to throw the earmuffs away & fresh water flush in drum/tank due to the shallow water pick up underneath the cavitation plate.
Is the accurate or is there a way to plug off the shallow water intake & still use the earmuffs?
Thanks in advance
Mike D
Thanks in advance
Mike D
