Hey guys,
Have an older Stamas fishing boat that has a Yamaha 350 inboard and out drive. Boat has sat for about a year and I fired her up yesterday and she purs like a kitten. The boat is stuck in reverse though. I followed the shifter cable from the throttle down the engine, checked the bracket on the engine and followed the cable from the engine to the out drive and it looks like the cable going into the out drive is messed up. So I started pulling this Yamaha out drive, pulled the 6 bolts and the 2 trim pistons and the drive still wont budge. Is there a trick to pulling these Yamaha drives? Usually you just pull the 6 nuts and remove the trim pistons and the drive pops off. It looks like the previous owner bumped the drive on the bottom or a rock because the prop is beat up pretty badly so I'm thinking when that happened it messed up the cable inside of the drive? Any help is greatly appreciated!!
