First post, and first boat
I purchased a boat form my inlaws for very cheap, the only issue with it is the engine. The 17.5 foot came with a 3.0 Cobra 302BPRPWS, a 90's model. The Block is cracked and letting water in and compression out. This is from a bad winterizing job from a company the in'laws fought with for 3 years. Guess they couldn't afford a lawyer
Regardless the 3.0 is obsolete and I'm having issues finding a remanfacured GM 181 for a decent price. So, what do you think my options are here? From what I understand the bell housing bolt patterns are the same on the early year mercruisers and 4.3L cobra V6's.
The Mercruiser and V6 4.3 are a dime a dozen around here, but I just can't seem to find a decent 3.0 to put back in the boat. The 4.3 will need a new outboard and I think if I find a doner boat I can just use whatever it has graneted propper engine alignment with the different front mounting. Will a mercruiser require a different outboard? Wiring? head? Shifting cables? Throttle adjustment?
I'm mechanically competant and have lots o' time. I've rebuilt cars and thought I would try my hand at a boat. I know they arn't the same. But as far as swapping the engine goes, I'm a bit lost. Mainly due to the age of this block and.....well...it's a boat. When I look at it I feel like I'm hammering on a glass bottle.
