Water level has gone down on our lake and weeds are thicker than ever...
Problem: when I increase the the throttle the motor starts to idle high( scream) but the boat doesn't move forward at all.
I'll start slow and as I increase the throttle- the engine starts to rev and after a good minute or so the engine is idleing very fast (obviously I open up the throttle ) but she doesn't move. It appears the prop is spinning.
Diagnosis: I tried spinning the prop with the motor off but gear selector in gear or reverse & it seems to be stuck in gear .. not moving freely which I figure is a good sign.
Is this because of the heavy weeds or do I have a driveshaft issue ??
ohh - it a 1987 Johnson / Evinrude 30hp
Please advise,
M.
Please advise,
M.
