Specs: 87 Ford 2.3, supposedly new electric fuel pump, removed mechanical fuel pump, carb says GM Rochester 2jet, new fuel filter.
My boat is idling good on land, rough in the water, and doesn't like to rev up anywhere. I just got it and know little of it's history. The guy said it sat for a year and he thinks it is bad gas. I can't see the accelerator pump working(I should with the throttle open right?) so I looked inside the fuel bowl and it is kinda cruddy. I'm going to do some cleaning on it, drain the fuel, and put in some new. Am I on the right track or any other tips to help out?
Also, as I search the forum, I see a lot of fuel related problems with this motor. Where should I get quality parts for this carb or is there a better set up for this motor?
